Power supply for iMac retina late 2014
Which power supply should I buy ? Upper one or lower one ?
I linked below.
Is dit een goede vraag?
I linked below.
Hello,
You only posted one link... This part should be good as long and you correctly match the EMC#. You can put your serial in Everymac ultimate lookup to check you current models EMC#. Opening it up and replacing the PSU is the hard part.
BTW don't forget the Adhesive strips.
[gekoppeld product ontbreekt of is uitgeschakeld: IF174-005]
Was dit antwoord nuttig?
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 790
2 opmerkingen
As far as I can see, those are the same part. Perhaps you accidentally put the same link twice?
door Rachel Acosta
Are you sure you need to replace the power supply? Double check your cord is good and review the diagnostic LED's what are they telling you.
door Dan
