The left front wheel of my solar breeze keeps making a clicking sound
one of the wheels on my solar breeze keeps making a clicking sound when the wheel tries to engage.
Is dit een goede vraag?
I started having the same problem today. Did you end up finding a solution to it?
Thanks
Was dit antwoord nuttig?
the unit will not charge
the unit will not take a charge
I have the same problem too. On reading the user manual I noticed that they say to never rest the panel on the front wheels. I might have done that a few times to charge it and thus might have bent it. I did infact try to repair it by removing the covers, I saw nothing there blocking the wheel. The wheels do work if you put a small pressure on them but they stop working after a few seconds. I will try to dig into it again sometime.
My front wheels also started to make noise. You can contact the company and they'll sell you a "front gear platform" replacement kit which you can install yourself as per their published video https://youtu.be/kGRnaAwNPjU
Or you can purchase RX for your NX maintenance plan where you send the unit to them and they replace whatever needs to be replaced as per https://solar-breeze.com/product/rx-nx-s...
For me, rather than replacing many components in SolarBreeze every year or two.... I'm considering a more wholistic solar solution from http://www.naturalcurrent.com/sunray-sol...
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 7
Afgelopen 30 dagen: 16
Altijd: 2,786
In my case, the cone-shaped horizontal pinion gear is worn and not engaging with the opposing gear. I have a replacement part but don’t know how to remove the pin that the cone gear attaches to. Any ideas?
door James Dee
