Should I change the logic board myself?
Hello everyone!
My MacBook Air (Mid-2013: 256GB 1.3 GHz 4GB) stopped working since August 14, 2017. At first I thought it was just a drained battery, I charged it, but something seems wrong.
Sometimes the LED on the MagSafe connector would light up but eventually turn off that it isn't charging anymore. I brought it to an authorized Apple service center on the mid of September. The repair guy told me they found corrosion on the main logic board of my system, specifically near the airport card. They also told me that the only remedy to this problem is to change the main logic board which costs about the same as buying a new MacBook Air. I didn't ask any further, I told them I wanted my system back and walked away from the service center.
I ordered the screwdriver from iFixit so that I could check the inside of my system myself to see if there is really corrosion on the logic board. I didn't find any corrosion as what they said they saw. But, what I noticed was more surprising. I saw condensation on the logic board of my MacBook Air.
So I swabbed the surface of the logic board with a Q-Tip with alcohol and let it go dry.
After this I tried to charge my system and surprisingly it booted up but then it went off after having gone to the desktop. I tried recharging my system but this time it wasn't charging anymore. It only shows the amber light on the magsafe connector until eventually the magsafe light would not come on.
Can someone help me? I don't know if I would change the logic board of my system or just the I/O board or what.
Is dit een goede vraag?
7 opmerkingen
Your Logic board needs ultrasonic cleaning to remove the corrosion. Hopefully there aren't any dead chips on the board.
door Anthony
Where about do you live? Condensation within the system is rare.
You might need to be more careful as the humidity maybe very high were you live. Often walking from an air conditioned location to the humid air outside can be the source of the moisture.
Consider getting a plastic bag to wrap your system up in (air tight) so you can pack it up in the cool dry location before going out, and leaving it in the bag until the system has warmed up to the temp were you're using it, if that location is humid. In any case you'll need to shut your system down, not sleep as the bag will cause the system to overheat otherwise.
door Dan
@roxdacullo post some images of where that corrosion was located on your board. That may give us an indication on wheat part of the board my give you issues right now. Use this guide Voeg afbeeldingen toe aan een bestaande vraag to do so. Skip the plastic bag in humid environments since that will increase condensation and will only lead to more trouble.
door oldturkey03
Have the same problem as Roque and I live in Manila. Were you able to change your logic board, Roque? Where can you buy the parts? Also thinking I have a battery problem. Took my 13 inch to the service center so waiting the official diagnosis.
door Samurai Jane
FYI - IFIXIT ships to Panama. If you know anyone in Hong Kong you might be able to get a logic board their as well.
door Dan
2 commentaren meer tonen
