Ga door naar hoofdinhoud
Achtste generatie van de Honda Civic.
I cant get my check engine light to stay off
on my 2006 honda civic 1.8l ex my check engine light will not stay off. comes back on in 1 second. codes read p0498 & p0135...i installed a brand new 02 sensor. haven't gotten to the vent valve as of yet because my light keeps coming right back on. checked all fuses (good). i even checked the wiring going to the 02 sensor with my meter. not getting the full 12v but i get somewhere around 2v-1.8v. i thought that was strange but i don't know it could be normal. is there anyone out there who could please help me or give me a little insight !!!
Update (10/05/2017)
Oh and I forgot to add i checked my new 02 sensor. the resistant was 3.9 using Ohms on the multi meter
Is dit een goede vraag?
Score 1
1 Opmerking
Yes this is a common issue for the (8th generation) 1.8L civic years 2006-2010. The Catalytic converter is dirty/clogged causing the O2 sensor to throw the code. The black market High flow cats are between $120-$200 decent onesdepending on brand etc. About exact replacement as you can get, for this type of replacement which is comes off the front of the engine manifold ( under the hood).
door
Voeg een opmerking toe
1 Antwoord
Filteren op:
Gekozen oplossing
Levy brown P0135 is a malfunction with the 02 sensor and you did not tell us which one you replaced. The voltage should be around 0.1V to 0.9V. P0498 is the EVAP canister vent shut valve circuit low voltage. It is absolutely possible that you have a vacuum line that is off or broken. You also want to check your gas cap and think about replacing it. After changing them and fixing the vacuum line clear the codes. You are also not telling us how you cleared the code after your repair. You will need a code reader tool connected to your ALDL connector to clear those. I suggest you check at places like Autozone etc. for that.
Was dit antwoord nuttig?
Score 2
Voeg je antwoord toe
Levy brown zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 9
Afgelopen 30 dagen: 32
Altijd: 3,527
