Ga door naar hoofdinhoud
MacBook Pro-modellen met een 15" scherm
8244 Vragen Bekijk alle
Liquid Spill disassembled screen is flickering and unsteady?
model A1286. removed back of laptop all appeared well. Screen is flickering and unsteady. Otherwise the computer appears to be working very well! Any ideas on diagnosis?
Is dit een goede vraag?
2 opmerkingen
Thank You Machead3 for your answer. Of coarse it would be important what it was that was spilled. Never thought about corrosion. I decided to take it in to get checked. Thank you for your support. I love this site! I'll let you know how it goes.. Thanks again. Charlie
door
Best of luck to you.
door
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
Dismantle
clean and dry. Depending upon what was spilled corrosion may start worsening symptoms. Follow tags to see how to treat liquid damage.
Remember to return and mark as accepted the answer that best solves your problem.
Good luck,
N
Was dit antwoord nuttig?
Score 1
Voeg je antwoord toe
Charlie Black zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 2,276
