Why is my printer skipping lines of text?
Hi,
I have an Epson XP 330. I have been trying to print a paper and it keeps skipping lines of text. I have done a nozzle check, cleaned the printhead, and also done an alignment SEVERAL times. Is there something else I can try? I feel like I am wasting ink and paper doing the alignment over and over, and I don't even know if I am doing it correctly. It started to skip less lines after the first alignment, but it's still not working and hasn't improved after the other alignments. I am a college student so my printer is essential... HELP!
Is dit een goede vraag?
6 opmerkingen
I was first suspecting that printing on cardstock was causing the feeding to not be able to feed plain paper through the paper feed correctly. Is there a way to fix the paper feeder so that it can feed paper without skipping lines?
door bonniej609
Wow! Problem fixed! Thanks you! It’s been like that for months!
door ggcoralysp
I just went back to an HP printer with expensive ink. Never had problems with HP!
door H Frederick
My Epson wf 2750 prints the lines but won’t print the words or numbers
what can I do
door bcappsmidwife
Having the same issue. Doesn't matter graphical or text, evenly spaced blank lines occur along the page. However, the issue only occurs when printing in STANDARD quality mode. When I change the quality to HIGH, the lines disappear..... very confusing. Could this be a driver issue?
door Vincent Sojka
1 commentaar meer tonen
