Ga door naar hoofdinhoud
Model A1419 / EMC 3070 / Mid 2017 / 3.4, 3.5 or 3.8 GHz Core i5 or 4.2 GHz Core i7 Kaby Lake Processor (ID iMac18,3) / Retina 5K display. Refer to the older iMac Intel 27" Retina 5K Display (Late 2014 & 2015) guides as the system is very similar.
281 Vragen Bekijk alle
iMac 27" 2017 modular CPU?
Has the iMac 27" 2017 a modular CPU or is it soldered?
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
The newest iMac is just a speed bump from the 2015 model. Here is the 2015 IFIXIT teardown you can review: iMac Intel 27" Retina 5K Display Teardown
So far Apple has stayed with socketed CPU’s in the 27” models, unlike the 21.5” which has been a bit of a hit or mis as the low end model was soldered. The newer 21.5” 2017 model is back to a socket! So Apple appears to have heard the cry’s iMac Intel 21.5" Retina 4K Display 2017 Teardown
OK, so it’s socketed you still have limits here on what you can put in! You can only use the chips Apple has used in this series. And we don’t know what Intel is upto as far as sockets in the next round of CPU’s so if you are thinking jumping to the next gen forget about it!
iMac Intel 27" Retina 5K Display Afbeelding
Handleiding
Moeilijkheid:
Gemiddeld
iMac Intel 21.5" Retina 4K Display (2017) Afbeelding
Handleiding
Moeilijkheid:
Gemiddeld
Was dit antwoord nuttig?
Score 1
2 opmerkingen:
No problem! Enjoy
door
Voeg je antwoord toe
Andrea Carlo Franzosi zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 1
Altijd: 395
