Doorzoek deze discussie om de juiste plek te vinden voor je opmerking. Klik vervolgens op "Link je opmerking aan dit bericht" om je opmerking te verplaatsen.
5 opmerkingen:
Hi,
Has it worked OK before when connected to the computer?
Does it work OK if you try to copy or scan a document using the printer's control panel?
If it works when using the printer's control panel, what make and model of computer is it connected to and what OS is installed in the computer?
Hi,
door jayeff
Printerhead? what do you mean? or are you trying only to print from your pc?
door jbermudez27
Yes. It is not printing from computer or copy or fax
door lorenzo.walker
Hello jayeff,
It is not printing from computer, or fax, or copy. I have replaced all ink cartridges in printer
door lorenzo.walker
Hi lorenzo.walker,
Have you tried a 'Clean Printhead"operation from either the printer's control panel or the HP printer software in the computer?
On the printer press the Right Arrow > Setup > Tools > Clean Printhead.
Do it 2-4 times to see if it starts to print.
door jayeff
