Ga door naar hoofdinhoud
Model A1312 / Mid 2010 / 3.2 GHz Core i3 or 2.8 & 3.6 GHz Core i5 or 2.93 GHz Core i7, ID iMac11,3
309 Vragen Bekijk alle
iMac Vsync Cable Mismatch
My iMac 27inch Mid 2010 2.93GHz Core i7 (Model A1312-BTO/CTO EMC: 2390
I replaced the LCD Power board and now I have a mismatched VSYNC cable. The cable coming from the LCD is a few wires with a 4pin connector unlike the other temperature cables. The LCD board appears to be a ribbon cable?
Does the LCD panel have a way to remove the VSYNC cable from the other end? and if so how would I go about attaching the ribbon cable. Or is it unfortunate that i would just have to buy a new LCD power board that matches the VSYNC cable?
Thanks in advance for your help!
-Justin
Update (09/25/2017)
This is what I see.
Is dit een goede vraag?
Commentaar:
jea508 what do you refer to as the LCD power board? Do you mean the LED driver board or the graphics card?
door
Oldturkey03, Maybe I miss typed what i meant. It could be called the LED driver board. It's the board on the bottom left, about 6" long and about 5" wide. It's the board you are supposed to plug the vysnc cable into on the iMac.
door
Hi Justin,
I have just done the same thing. Currently the iMac is working without it connected. Did you ever find an answer to this problem?
door
Een opmerking toevoegen
1 Antwoord
Het nuttigste antwoord
jea508 the vsync cable attaches to the LED driver board
You should not have a LED board with a ribbon cable. This is what your board should look like.
Was dit antwoord nuttig?
Score 1
Commentaar:
Old Turkey, the board is infact the same board, but with a different connection for the vsync. I read somewhere in one of the ifixit.com instructions that the vsync cable could either be a ribbon, or a set of wires. My iMac screen has the set of wires coming from it with a 4pin connector, i fear the LED board has the ribbon end.
door
This is the connection I see when I open the iMac in the link below (I dont know how to add pictures to comments but I did add a picture to the original question if you don't want to click that link). However, there are "wires" from the lcd panel which has the 4pin that would fit the socket in the picture you provided.
https://d3nevzfk7ii3be.cloudfront.net/ig...
door
Voeg je antwoord toe
jea508 zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 Uren: 0
Afgelopen 7 Dagen: 2
Afgelopen 30 Dagen: 4
Altijd: 213
