Ga door naar hoofdinhoud
Model A1842. Released September 2017, the revision to Apple's 4th generation set-top-box featuring an A10X Fusion processor and 3 GB of RAM.
14 Vragen Bekijk alle
Does the Apple TV 4K have a fan on the bottom? Just curious.
It looks like (from pictures) that the Apple TV 4K has a vent on the bottom. I’m wondering if it has an active cooling solution (i.e. with a fan) or is just passive cooling (without a fan).
Is dit een goede vraag?
Score 1
1 Opmerking
Really want to see the teardown for this one! A10X with active cooling might be a screamer.
door
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
Until someone does a teardown we won't know for sure.
I suspect there is a fan and a heat pipe system. Why do I think that? If you review the images you'll see there is no other opening for the air to enter or exit (chimney effect) for a passive system. The air must be coming in on one slot set and exiting on the other side on the bottom being moved by a fan.
Was dit antwoord nuttig?
Score 1
Voeg je antwoord toe
Reid Fleishman zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 8
Altijd: 1,837
