Ga door naar hoofdinhoud
4-inch iPhone released in March 2016 with similar hardware specifications to the 6S. Available in Silver, Space Grey, Gold, or Rose Gold with 16/32/64/128 GB storage options. Model: A1662 and A1723
both camera's + flashlight not working.
hey people i got an iphone SE with both camera's and flashlight not working. the board looks perfect. the screen has been replaced some time but the customer says the camera's stopped working after a drop. any advice for this repair? i know about the camera jumper on the 6 an 6s.. but i dont know realy where to begin on this one..
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
The cameras and flash are on separate flexes. The only common denominator between those three is the CPU. Let's put that aside for now as it seems unlikely to be the problem.
I would check the voltage on the PP2V85_CAM_AVDD rail. It drives both cameras and the RCAM also sends an enable signal to the Strobe circuit (RCAM_TO_LEDDRV_STROBE_EN). In theory, if 2V85 is bad, then both cameras stop working and the enable signal to the Flash is missing, hence no flashlight.
If you don't have the tools or experience to troubleshoot at the board level, I suggest you seek out an experienced micro-solderer. If you can't find one locally, then consider mail-in repair. There are several reputable micro-solderers patrolling this forum.
Was dit antwoord nuttig?
Score 2
1 Opmerking:
Could you let me know if 2V85 is "BAV23S Dual high-voltage switching diodes"?
If not then what kind is it and where could I buy that one?
Thank you very much in advance.
door
Voeg je antwoord toe
thieske zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 1
Altijd: 1,664
