What is the maximum RAM I can install in an iMac12,2?
The iFixit page:
is contradictory.
COMPATIBILITY on the right says "All Mid 2011 27" iMacs"
But on the left it says:
"FEATURES
No, that's not a tpyo! You can have 8 GB in a single RAM chip.
Please Note: the Mid 2010 21.5" iMacs (EMC 2389) & 27" iMacs (EMC 2390) with the Core i3 and the Mid 2011 27" iMacs (EMC 2429) with the Core i5 can only accept up to 4 of the 4 GB chips. These will not work in your machine. "
Which is it?
and What does "EMC 2429" refer to?
and Where can it be found on my iMac?
Is dit een goede vraag?
3 opmerkingen
Here is the Apple T/N that explains how to add RAM in your system: Install memory in an iMac
Now keep in mind the section on the 2011 models was written awhile ago and Apple never certified the system would run more RAM that what they have published here. That’s not to say it won’t work only what they tested upto. Remember the 8 GB modules came out about 2 years later.
As for IFIXIT page notes. This to is an older posting and I suspect IFIXIT wants to stay consistent with what Apple published.
door Dan
Sometimes there is no firm answer... I know of people doing it and we did a few systems our selves.
We did encounter issues which we discovered was power related and once we used a good UPS it solved it. So this is pushing the boundaries of what the system can handle.
So... You need to deside do I need that much RAM to do what I need to do with this system or do I need to upgrade the system with one that has been certified as being able to support this much RAM as my work demands it.
Maybe you need to just give it a try and make sure the outfit you order the RAM is willing to take it back. Maybe you should just try going with two 8 GB modules to see how that goes first, then try adding the other 16 GB.
door Dan
I might add you need the newer system firmware in El Capitan or newer.
door Dan
