Vizio D39h-c0 has black screen, led backlights working
I have a vizio D39h-c0 that's has a black screen. The led backlights are working fine. I replaced the main board which is the only board I see besides the long circuit board at bottom leading to led lights. That didn't do the trick. I've read about possible T-con board or other boards but I'm not seeing any other boards in the tv and the main one has been replaced. Any ideas?
There is only 1 board that I can see. Is it possible everything is combined into one?
Is dit een goede vraag?
5 opmerkingen
Yes I have checked and it appears all is connected and nothing appears damaged
door eimaj711
I'm getting the same result. Sound, backlights, and my screen is blue. Not bright blue, but blackish blue.
=== Update (06/18/2018) ===
I have one the same way. Sound, backlights work. Remote turns it on and off. Screen isn't cracked. New board. Still black screen.
door Steve Allen
Anyone figure this out, remote turns off and on, but only result is a blackish blue screen. .
door jhatfield704
Same exact issue here, boards and capacitors all look ok. Did you ever figure it out?
door Eric H
Did anyone else here begin experiencing this after connecting an AppleTV? I was setting up my entertainment center in the home we just moved into. Connected my AppleTV 4K and had visuals as expected until suddenly the screen went black same as described here. LEDS are on but displaying only black. Can not see anything else. No output from AppleTV and no overlays when trying to get a source or setting menu to appear with TV remote. Do I need to consider this TV broken and in need of replacement?
door Cameron Brown
