Ga door naar hoofdinhoud
The Xbox One S, designed by Microsoft Corporation, was released on August 2016. The Xbox One S is a redesign of the Xbox One.
20 Vragen Bekijk alle
Powers on shortly then powers off
As the title describes, the xbox one s powers on, then quickly powers off when the power button is pressed.
Is dit een goede vraag?
Score 2
1 Opmerking
I am having same problem
door
Voeg een opmerking toe
2 Antwoorden
Het nuttigste antwoord
I also have this issue just took the entire xbox apart and cleaned it nothing appears to be wrong with the fan as you can hear it click on but I do believe the power supply needs replaced. I am ordering one to see if it fixes the issue.
Was dit antwoord nuttig?
Score 1
1 Opmerking:
Did this work?
door
try replacing your fan and power supply.
Voeg je antwoord toe
Dan N. zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 344
