Ga door naar hoofdinhoud
The Nintendo DSi is the third iteration in the Nintendo DS line, and made its debut in Japan in late 2008.
244 Vragen Bekijk alle
How to Replace the DSi charging socket on the motherboard?
I need to replace the charging socket on the motherboard but don't know how to remove it w/out frying my motherboard (looked all over the place but can't found any guides that are revelant). This is the part I'm talking about.
Is dit een goede vraag?
Score -1
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
Remocleus, check on here http://surugi.com/projects/DSLiteUSB.htm... and see if that helps you out to see hat needs to be done. Here are all the steps that you would need to get to your plug.\ DSi Repair Still trying to find you more of a service manual but hope this will help.
Was dit antwoord nuttig?
1 Opmerking:
Thanks that desoldering guide is just what I was looking for : )
door
Voeg je antwoord toe
Remocleus zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 4,875
