Ga door naar hoofdinhoud
The Nikon D80 is a digital, 10.2 megapixel, single-lens camera that was released to the public in 2005. It is meant for digital photo-taking and filming.
25 Vragen Bekijk alle
Takes photos without any error but the photos are black
It started with weird shutter noises, when I press the shutter button to take a photo it sounds like I am holding the button to take multiple photos (but sounded much more quiet than usual) after that there was the err message. On the next try it takes the photo normally like always without any problem.
This problem started to occur much more often until the camera stopped taking photos completely. I could hear the mechanism working but the err message was all the time showing and no photos were saved. I wasn't able to change the settings in manual (speed, aperture, iso, wb) the flash wasnt opening.
Since its old camera I decided to change the shutter assembly so I got new one from ebay
I soldered the new one and exactly the same problem continued happening...
So I found this video on yt and decided to do the same thing.
So now err message is gone, I can change modes and settings, flash fires, photos are saved but all of them black with and without lens on manual even on long exposures (I can see the sensor, mirror and shutter are raised) and the camera mechanism sounds normal.
Exposure mode in EXIF is unknown
Any suggestions what could be the problem
Is dit een goede vraag?
Score 1
Voeg een opmerking toe
2 Antwoorden
Het nuttigste antwoord
I had the same issue (black photos after fixing the broken plastic on the aperture wheel). For me the problem was that I didn’t properly reattach the CCD flat cable when re-assembling the camera. When I removed the back panel and attached the CCD cable properly, the camera started working fine.
Was dit antwoord nuttig?
Score 1
@nenadbogoevski with all the parts you already replaced and modified, my next step would be to replace the CCD/PCB unit
Voeg je antwoord toe
nenadbogoevski zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 12
Altijd: 543
