I would like to identify a broken flex in the upper right corner
I would like to identify a broken flex in the upper right, just to the left of the rear camera. There are 4 snap connectors here.....this one that I have broken, then 2 others and then the rear camera (extreme right). It's the smallest of these flex connectors and I'd like to identify it to test the operation and to order a replacement.
In the photos the red spot is visible where the connector has started to separate.
Can anyone help please ?
Is dit een goede vraag?
5 opmerkingen
Can anyone identify this flex please ?
door malcolm watson
I wish i could for you. I'm not sure what that is responsible for.
door musick.jesse
I have since found that the iPad has no 4g connection when it has a SIM card .
So I think now that the flex is connected to the cellular aerial.
Can anyone out there confirm this or recommend the part that I need to order and replace.
door Kate & Malcolm Watson
A complete new cellular unit came with this very small flex (the complete Unit was very inexpensive in the end ( <$4)
I just got my comment flagged but i don't think you can post links. Look up "4G ANTENNA FLEX CABLE FOR IPAD AIR 2 (RIGHT SIDE)" from mobile sentrix
door Khai Nguyen
