Ga door naar hoofdinhoud
Cellular version of Apple's 2nd generation iPad Air. Model A1567.
83 Vragen Bekijk alle
I would like to identify a broken flex in the upper right corner
I would like to identify a broken flex in the upper right, just to the left of the rear camera. There are 4 snap connectors here.....this one that I have broken, then 2 others and then the rear camera (extreme right). It's the smallest of these flex connectors and I'd like to identify it to test the operation and to order a replacement.
In the photos the red spot is visible where the connector has started to separate.
Can anyone help please ?
Is dit een goede vraag?
Score 2
5 opmerkingen
Can anyone identify this flex please ?
door
I wish i could for you. I'm not sure what that is responsible for.
door
I have since found that the iPad has no 4g connection when it has a SIM card .
So I think now that the flex is connected to the cellular aerial.
Can anyone out there confirm this or recommend the part that I need to order and replace.
door
A complete new cellular unit came with this very small flex (the complete Unit was very inexpensive in the end ( <$4)
door
I just got my comment flagged but i don't think you can post links. Look up "4G ANTENNA FLEX CABLE FOR IPAD AIR 2 (RIGHT SIDE)" from mobile sentrix
door
Voeg een opmerking toe
2 Antwoorden
Het nuttigste antwoord
Take a photo of it and post it here.
Voeg afbeeldingen toe aan een bestaande vraag
Was dit antwoord nuttig?
Score 1
I realize this is five years too late, but for anyone else who comes across this, this cable is the right LTE/cellular antenna connector. It is grafted to the black module along the top of the device between the rear and front cameras, and connects to the logic board via a small coaxial connector.
Voeg je antwoord toe
malcolm watson zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 321
