Ga door naar hoofdinhoud
The Xbox One S, designed by Microsoft Corporation, was released on August 2016. The Xbox One S is a redesign of the Xbox One.
426 Vragen Bekijk alle
Help with stuck Xbox Controller B button
So, I have a Xbox One S controller with a stuck B button. I called Microsoft and they are sending me a new one and letting me keep the old one. So, I was wondering if I could fix the messed up button. It registers as pressed constantly but is not physically stuck. Has been tested on 2 Xbox Ones and a PC.
Is dit een goede vraag?
Score 3
Voeg een opmerking toe
2 Antwoorden
Gekozen oplossing
You can try this teardown below and see is something is possibly jamming the B button under the rubber as shown in step 8. It might be a software issue as well, but it's worth a shot to take it apart if it's not working anyways.
Xbox One Wireless Controller Teardown
Was dit antwoord nuttig?
Score 4
4 opmerkingen:
Thanks! I’ll try this. It’ll have to go on my teardown table tomorrow!
door
This worked! The button was caught somehow on the paneling. I broke the haptic motor doing it but I have a soldering gun...
door
Ayyy, good to hear. Glad you figured it out and good luck with the re-soldering
door
I don't know how to solder I have a brand new well two-week-old Xbox One controller and the a button is sticking it's not dirt and I don't know how to solder I also don't take apart controllers I don't have that level of high-tech is there help please I need to fix my controller and I'm kind of limited Q-tips and alcohol fix dirt it's not dirt
door
Rubbing alcohol on a q tip wipe around edge of button and press the button rapidly no more sticky button your welcome
1 Opmerking:
As I said, it is not physically stuck, I don’t eat and game. It’s something within the device, it clicks just fine.
door
Voeg je antwoord toe
Reed Crosby zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 10
Afgelopen 30 dagen: 48
Altijd: 52,993
