Ga door naar hoofdinhoud
The PlayStation 3 Slim is the second version of the PS3 video game console with the original model number CECH-2000. Produced by Sony Computer Entertainment it fixed many issues of the original (fat) Playstation 3. It was released on September 1, 2009.
465 Vragen Bekijk alle
Error 80010017 trying to play any game, everything else Ok
Hello friends,
I'm receiving the error 80010017 in my almost new PS3 slim. Everything appears Ok but when I try to play any game I allways receive the error message.
I found in the following link, details and video that describe the error but never got an answer.
http://psx-scene.com/forums/f177/ps3-pro...
I will really appreciate all you do to help me.
Regards,
Erich
Is dit een goede vraag?
Score 8
1 Opmerking
hao to fix this rerror
door
Voeg een opmerking toe
9 Antwoorden
Het nuttigste antwoord
Erich give this a try I believe that there are also firmawre issues connected with the error code and I believe that some users have had luck with reactivation. Go into into Account Management ([Friends] [Account Management]), de-activated and then re-activate again. If that does not work and you are having ssues with all o your games, it is most likely that you will have to replace your BR drive. It is caused by the BR no reading your disk., Could be a mis-alligned or dirty laser as well as other drive issues.
http://www.keepandshare.com/doc/2510513/...
http://www.keepandshare.com/doc/2510514/...
http://www.keepandshare.com/doc/2510523/...
http://www.keepandshare.com/doc/2510524/...
Is a large manual that can help you to repair and modify your PS3 That is really all I can offer at this time. Good luck with your console.
Was dit antwoord nuttig?
Score 2
My game Last of Us is getting this message
Its not a downloaded game
I have finished the game but started to replay
And there was a update so I updated and it wouldn't load
So I deleted the data but now I'm getting 10080017
Any help
Score 2
Hello, I am getting this error with only one game I downloaded, Warhammer 40,000, all other games work fine. No, I will not reformat my brand new hard drive just to hopefully get ONE game to launch. I have downloaded and installed 3 times with same result. I have de-activated and activated games authorization. What will fix this?
Score 1
It depends, if other games are excuted just fine and one does not, then it's a firmware issue.
You can just upgrade to latest version. Most of the time, Jailbreak users may encounter this error on latest games. Which is obviously the game is designed only to work on latest firmware due to it's encryption.
Score 1
hi i a erro fixt to wanna the
It's either your disc reader that's broken or the game cd is damaged
Hey..
Can someone help my console will let me play only dead island, and when I try to play for instance gta5 i get that annoying error code.. Any ideas
I whant to play games
go to: any advice or known fix for ERROR 80010017?
and click Answered! View the answer and read it
Voeg je antwoord toe
Erich Sanchez zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 13
Afgelopen 30 dagen: 43
Altijd: 55,960
