Ga door naar hoofdinhoud
Model A1224 / Early 2009 / 2.66 GHz Core 2 Duo processor
104 Vragen Bekijk alle
It is grayed out on iMac
My Mac cd dvd is grayed out
Is dit een goede vraag?
5 opmerkingen:
And which of the many different iMac's do you have as well as the OS-X version
door
OS X Capitan Version 10.11.6
door
10.11.6 is your operating system. We are trying to find out which iMac you have. You can get this info under "about this Mac" or on the bottom of the iMac stand.
door
IMac 20 inch, Mid 92007)
door
IMav 20" Mid (2007)
door
Voeg een opmerking toe
1 Antwoord
the most common reason is that a blank disc has not been inserted yet
UPDATE 8/30/17
Sounds like your drive has failed. Time to replace it as these things are almost impossible to repair once they fail. Here's how to do it:
iMac Intel 20" EMC 2266 Optical Drive Replacement
Was dit antwoord nuttig?
3 opmerkingen:
Tried that did not work. But thank you
door
Will it read a disk? What are you trying to do when you see the greyed out icon?
door
No it does not when I put a disk in it ejects it it still grated out when I put the disk in.
door
Voeg je antwoord toe
c.severini zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 73
