Replacement battery won't charge
Successful replaced my iPhone 6 battery but it won't charge past 1%
Any ideas
Is dit een goede vraag?
Any ideas
It is possible that your replacement battery is defective. It also sounds like the problem was more with the charging circuit than the battery.
If you have access to a USB Ammeter, you could use that to determine if the phone is really drawing current when it says it's charging.
I would try a known-good battery to eliminate that possibility. Otherwise, you will need to have your phone looked at by a micro-soldering repair shop.
Was dit antwoord nuttig?
What was the point to change your battery? Are your phone wont charge or you had battery drain?
Did it charge before you changed it ?, if it did you have a bad battery. If not you more thank likely have bad tristar and / or active diode.
If your previous battery did not charge at all you should check the charger. Check the voltage across the terminals with a DC voltmeter. If it has some value close or higher than nominal battery voltage the new battery most likely has a problem.
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 126
