Ga door naar hoofdinhoud
Repair and disassembly guides for screen doors.
Screen door won't close completely without my lifting it into place.
Screen door won't close completely without my lifting the closing pieces into place. Can this be fixed?
Is dit een goede vraag?
1 Opmerking
Thanks ever so much. So nice to have the screen door fixed!
door
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
This is very common. Usually the door drops. First tighten the upper hinges and see if that pulls it up. If not you may have to put a shim on the lower hinge to push it out. When doing that I would start with an 1/8" shim and try it with the screws out and see if it is enough. If not add another one until it gets aligned.
Was dit antwoord nuttig?
Score 1
Voeg je antwoord toe
Jane zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 4
Afgelopen 7 dagen: 17
Afgelopen 30 dagen: 74
Altijd: 4,432
