First generation Apple iPad with Wi-Fi, available with 16, 32, or 64 GB. Model Number A1219. Repairs are straightforward and do not require heat.
138 Vragen Bekijk alle
replace mother board with a raspberry pi zero w
i have a Apple ipad gen 1 and 3 not being used
is it possible to replace the mother board with a raspberry pi zero w
it has usb, bluetooth, wifi etc. it needs hdmi for output and battery
apple ouputs hdmi so it must be there
check out web site raspberrypi.org
I have this card and it work fine. it is the size of a credit card
rich
Beantwoord! View the answer Dit probleem heb ik ook
Is dit een goede vraag?
Een opmerking toevoegen
Gratis verzending van alle bestellingen van meer dan US$ 100,00 of met een Pro Tech Toolkit!
Doorblader onze winkel
3 Antwoorden
Gekozen oplossing
Likely not. You would need the schematics on how to connect the battery, Charge port, LCD, and buttons to the Raspberry Pi board. It also will not run Apple iOS, just the barebones Linux Raspberry supports.
Was dit antwoord nuttig?
Score 2
He's trying to sell you his crappy boards @kaykay
Score 1
it looks like there is a board for the charger so i need + 5 volts 2 wires
also a board for the hdmi format. 2 wires
raspberry os works fine i can use ssh and sftp commands both ways
i have both PI 3 and zero w bluetooth keyboard works fine
raspberry has a 7" display for $70 I might go that route
Richard
Voeg je antwoord toe
Richard Schwendler zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 Uren: 0
Afgelopen 7 Dagen: 1
Afgelopen 30 Dagen: 10
Altijd: 252
