Ga door naar hoofdinhoud
The X5 Max Pro is a low-end slate Android smartphone released by Doogee in June 2016. This device has no readily available model number.
3 Vragen Bekijk alle
Ghost touch while playing MOBA games (Mobile Legends)
While I am playing Mobile Legends, I experience ghost touch in which I the touch point is bit far from from where I am touching. I played different MOBA games and the same issue I experience. Any help is accepted.
Is dit een goede vraag?
Score 1
Voeg een opmerking toe
3 Antwoorden
Umm I also play mobile Legends but you can go and you will see a gamemode you recently played ,the chests, events and the shop then you will see at the top a person with headphones press it and you type your problem and then the person will help you.
Was dit antwoord nuttig?
Try replacing the digitizer.
Cara memakai cit gimana
Voeg je antwoord toe
Elmer Fang zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 2
Altijd: 434
