The Apple iPhone 5s was announced on September 10, 2013. Repair of this device is similar to the previous models, and requires screwdrivers and prying tools. Available as GSM or CDMA / 16, 32, or 64 GB / Silver, Gold, and Space Gray.
3788 Vragen Bekijk alle
Displayfehler nach Austausch Displayissues after replacement
Hi Folks,
i got an iPhone 5.
My Pal crashed it to the Floor an few months ago, the Display was broke.
He gave it to an very cheap repairman who replaced the Display.
My Pal didnt use it since then because he buy a new Smartphone.
Now he want to sell it but it seems that the Display doenst work very well - there are white Stripes all over the Display an very low constrast.
Its to late to complain at the repairman who replaced it.
What do you think it is?
Garbage-Replacement-Display?
bad connection inside?
what should i check ?
greetings
Beantwoord! View the answer Dit probleem heb ik ook
Is dit een goede vraag?
Een opmerking toevoegen
Gratis verzending van alle bestellingen van meer dan US$ 100,00 of met een Pro Tech Toolkit!
Doorblader onze winkel
1 Antwoord
Gekozen oplossing
Guten tag Baumgardt1.
Most repair shops offer some kind of warranty on their work. I don't know what is standard in Germany/Austria so you should reach out to the repair shop and see what they say. You either have a a screen connection issue or a defective screen. Did it ever work properly after the repair?
If you want or have to do things yourself, then the first thing to try is to re-seat the connectors. Open the device following this guide. Always disconnect the battery first and keep track of the screws. Putting the wrong screws in place can cause serious damage to the logic board.
If that doesn't solve your problem, than you have a defective replacement screen. You can find a good one here.
iPhone 5s Screen afbeelding
Product
iPhone 5s Screen
$49,99
Was dit antwoord nuttig?
Score 1
Voeg je antwoord toe
Baumgardt1 zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 Uren: 0
Afgelopen 7 Dagen: 0
Afgelopen 30 Dagen: 0
Altijd: 19
