Ga door naar hoofdinhoud
Fourth generation iPhone. Repair is straightforward, but the front glass and LCD must be replaced as a unit. GSM / 8, 16, or 32 GB capacity / Model A1332 / Black and White. This page aims to help users troubleshoot, fix, and seek help for the iPhone 4.
2396 Vragen Bekijk alle
Why isn't my battery not charging after 18%?
my iphone 4 is not charging after 18%.but the charging icon is appearing.but it isn't charging.i removed the battery,cleaned the ports with a brush and replaced it.but the problem is still there.what should i do?
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
Did you replace the battery with a new one or just put back the original? For such an old device, I would certainly suspect the battery too. However, there are some really poor quality batteries on the market and depending on where you bought it (or will buy it), you have to be careful.
If you need to order one, I would certainly recommend iFixit batteries.
Now, if the battery you replaced was new and from a reputable supplier like iFixit (as opposed to eBay), there is a possibility that you have an issue with your charging circuit on your logic board. That can be caused by using fake chargers and cables, especially car chargers from the dollar store or gas station.
iPhone 4 Battery Afbeelding
Product
iPhone 4 Battery
$11.99
Was dit antwoord nuttig?
Score 3
Voeg je antwoord toe
siyath dharmarathne zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 3
Altijd: 69
