Ga door naar hoofdinhoud
internal storage full with sd card
the phone has problems with internal storage full , I have a sd card installed what do I need to transfer and how to transfer to sd card . please help me resolve this issue . Thank you
Is dit een goede vraag?
Score 1
Voeg een opmerking toe
3 Antwoorden
Gekozen oplossing
Hi!
Moving apps to the SD Card on Android is quite easy. Since there are many different versions of Android, whatever screenshots I post here may prove useless, but here a breakdown of what you will have to do:
Go to Settings, scroll down until you see a section called Apps. Tap it. Here you will see a list of all apps installed on your phone. Select the app(s) that you want to move (please note that not all apps can be moved around). You will see a screen with additional information about that app along with it's current location (whether it's on the internal storage or on the SD Card), underneath that should be a button called "Change" (apps that can't be moved around don't have this button). Tap that, select the SD Card from the pop-up menu and follow the on-screen instructions.
Was dit antwoord nuttig?
Score 5
1 Opmerking:
Thank you! I am soooo glad I found this! Every other search was complicated, this was straight to the fact. Also, I knew that some apps would not be able to be moved to the SD card, but I never got enough info to move them. No more "out of space" warnings! Thank you!
door
So what can I do if my phone does not have this “change" option like how did I go about switching the apps to the ad card???
2 opmerkingen:
I just bought a 32GB SD card so I can free up my internal storage and not no where do I see in the storage settings this "change" storage option
door
I have the same problem, I don't have the change icon !!!! What should I do?
door
Hi I had same problem with an Alcatel POP4 - After many hours of wasted time I concluded that there was no solution and purchased a Samsung Galaxy
Voeg je antwoord toe
kim hughes zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 3
Altijd: 14,682
