Ga door naar hoofdinhoud
Repareer je spullen
Recht op reparatie
Onderdelen & Gereedschap
A1708/EMC 3164 — Released June 2017, this entry-level MacBook Pro retains its traditional function keys (as opposed to the OLED Touch Bar).
232 Vragen Bekijk alle
Is the SSD soldered on?
Dear Everyone,
I am wondering whether or not I should buy the 13" MacBook Pro 2017, without the touchbar. One of my questions in this regard is whether the SSD in the MacBook is repairable after purchase. I tried to ask Apple, but they gave me different answers.
Thank you in advance.
Beantwoord! View the answer Dit probleem heb ik ook
Is dit een goede vraag?
Voeg een opmerking toe
Essentiële Electronica Toolkit
Kleine toolkit. Grote dromen.
Shop Toolkits
Essentiële
Electronica
Toolkit
Shop Toolkits
1 Antwoord
Gekozen oplossing
The 13" with function keys does have a removable SSD. But! It's a custom part so it will only be available from Apple.
If you need to salvage something on the drive (if you killed your system some how) you would need to buy the exact same system as presently no one makes a case to hold the drive like what OWC does for the older models: OWC Envoy Pro USB 3.0 Enclosure For Apple Flash SSDs (June 2013-Current Mac Models)
As far as repairability or upgradability... Its about the same as the older 2015 model which is not good ;-{
Here's the IFIXIT teardown on the 2016 model which is exactly the same as the 2017 model: MacBook Pro 13" Function Keys Late 2016 Teardown
If you think the Touch Bar is better here's the IFIXIT teardown for it: MacBook Pro 13" Touch Bar Teardown which has a lower score of One!
MacBook Pro 13" Function Keys Late 2016 Afbeelding
Handleiding
Moeilijkheid:
Gemiddeld
MacBook Pro 13" Touch Bar Late 2016 Afbeelding
Handleiding
Moeilijkheid:
Gemiddeld
Was dit antwoord nuttig?
Score 2
Commentaar:
Dear Dan,
Thank you for your answer. So you can replace the SSD, if you e.g. find a used, identical MacBook Pro and use its SSD?
Kind regards,
Yousif
door
Voeg je antwoord toe
Yousif N. Al-Saif zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 23
Altijd: 2,232
