How do I change the motor mounts?
The engine vibrates when I accelerate. When I change gears, the engine moves a lot.
Is dit een goede vraag?
@rjasonford not quite convinced that this is caused by the motor mounts. I attached the Engine Removal part of the SM with this answer. That manual shows the mounts and how to pull the engine to replace those. Not an easy job.I would suggest that you check the motor and transmission mounts first. Also, rule out engine performance issues (fuel delivery, emission control etc. ) and check your vacuum hoses etc. Honda CRV Engine removal
Was dit antwoord nuttig?
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 2
Altijd: 1,156
Did motor mounts fix this? Kcnoblitt@yahoo.com
door Kenneth Noblitt
