Spilled juice - only fan and indicator light turn on
Working on a friend's MacBook, her son spilled juice on the right side of the key board. Unfortunately he did not turn it upside down straight away, nor did he turn off the power and remove the battery. It has been nearly a week. I disassembled the unit using a step by step from this site; cleaned the logic board in situ with cotton swaps and distilled water, cleaned the RAM contacts, checked hard drive contacts. Reassembled, only the cooling fan and indicator light turn on. At start up the display has an ever so slight flicker then nothing. The optical drive will not accept a disc. Logic board??
Is dit een goede vraag?
3 opmerkingen
Can you boot to target disk mode?
door rab777hp
Unable to boot, no response save for the cooling fan and indicator light.
door Kevin
Have you thought about the power supply at all?
door rab777hp
