Hard Drive Max Capacity
It is stated here that the maximum capacity of a hard drive is 500GB, WD for example go up to 1TB. Would this not work? If so, what is the reason for the limited capacity?
Is dit een goede vraag?
While I haven't tested it, it should definitely work.
Here's the reason: 500 GB was the largest laptop hard drive out there at the time of writing (and the largest we carry). :)
Was dit antwoord nuttig?
I assume you're talking about internal laptop drives, since your post indicates you have a MacBook Pro.
The only limitation is the availability of drives. The largest laptop drive generally available is 640gb, though Ben says elsewhere that WD has a 1TB (and there will surely be more before long.)
Desktop drives are up to around 2TB now.
If you mean external drives, well, then you can do a RAID arrangement with mind-boggling capacity. It would be helpful if your question were more specific.
I was reading this morning on a data recovery site that the higher-capacity the drive, the more likely it is to fail due to bad blocks, see here: http://www.dataclinic.co.uk/hard-disk-su...
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 1,389
