Ga door naar hoofdinhoud
Announced in March 2015, and released April 10, 2015, the Galaxy S6 is the next flagship in the Galaxy line. The curved screen version is known as the Galaxy S6 Edge.
487 Vragen Bekijk alle
Why is my phone not turning on?
This morning, my phone's power button and home button were not responding. I shut the phone down, which resolved the issue. Then the phone started turning off by itself. I would power up the phone to only have it shut off 2 minutes later. Then a static noise starting coming out of the speaker while it was on. It's now not turning on at all. The battery was at about 45% when this started happening. I've tried to hold the power button and volume down button...the Galaxy logo comes up and then shuts off again. And that only happens about half the time. The other half nothing comes up at all. I tried plugging it in, hoping a charge might help, but it has not. The phone is no longer plugged in but the red light is still on. Any insight would be appreciated!
Is dit een goede vraag?
Score 1
Voeg een opmerking toe
2 Antwoorden
Gekozen oplossing
And if you want to reflash firmware on the phone without using wiping data follow these steps:
http://updato.com/how-to/how-to-install-...
Was dit antwoord nuttig?
Score 2
Hello danielle ,
it seems some issue occur of your firmware,
1) download smart switch
2) select emergency recovery & initialization where located at right side
3) put the phone to download mode by pressing and holding (simultaneously) the Power, Volume Down and Home buttons
4) select continue option
5) follow the instruction given by smart switch
6) Wait while process completed
7) you almost completed!!!
Note : you have your own risk to do above steps!!! around 3GB-4GB of internet data will be required to download firmware.
Hope this solution helps you to fix your phone.
Score 1
Voeg je antwoord toe
danielle zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 3
Altijd: 1,054
