Ga door naar hoofdinhoud
Repareer je spullen
Recht op reparatie
Onderdelen & Gereedschap
Non-Unibody, Core Duo & Core 2 Duo Processors
491 Vragen Bekijk alle
Latch won't open after installing new harddrive
I upgraded my harddrive and installed OS without a problem, but after putting the case back together, the latch won't open fully, meaning I need to use the spludger to gently pop it open. I had a similar problem when I had my RAM upgraded last year, but the guys at the shop where I had it done were able to fix it. I'd prefer to not have to go back there again.
Does anyone know how to fix this?
Beantwoord! View the answer Dit probleem heb ik ook
Is dit een goede vraag?
Commentaar:
thanks for your help guys.....not sure what the problem was but it worked itself out....I think it was just an alignment issue
door
Voeg een opmerking toe
2 Antwoorden
Gekozen oplossing
Most likely is that the top case was improperly aligned improperly. It's impossible for us to tell over the internet. I would examine how it's binding and reseat the top case.
Was dit antwoord nuttig?
Score 2
Hi, it sounds like there may be a small screw lodged somewhere underneath or behind the push-button bar. I think you can remove that bar after you've removed the top cover. From there you can see if there is anything keeping that press bar from being fully depress.
Commentaar:
charles, I don't mean to be tacky but do you really think he's still having this problem after seven months?
door
Voeg je antwoord toe
stevehort zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 1,081
