Ga door naar hoofdinhoud
Model A1137 / 1, 2, or 4 GB capacity / black or white plastic front
68 Vragen Bekijk alle
Why won't itunes on my Windows 10 computer see my 1st gen nano
I've tried loading different versions of ITunes (the older versions seemed to be compatible before).
Now not only iTunes won't see my device, my computer won't either?
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
Hi @kiri
Check if your device manager detects your device.
Is your device charging?
It could be replaced by "helpful" windows generic drivers by windows update.
Try this: (From Apple Help)
If iTunes, and the Apple Mobile Device Service are apparently installed correctly, try the following:
Open Control Panel > Device Manager
Plug in your device
Locate Universal Serial Bus Controllers > Apple Mobile Device USB Driver.
It is also possible the device may show under Imaging Devices, Portable Devices or Other Devices or as an MTB USB Device.
Right-click and select Update Driver Software...
Click Browse my computer for driver software
Browse to C:\Program Files\Common Files\Apple\Mobile Device Support\Drivers or
C:\Program Files (x86)\Common Files\Apple\Mobile Device Support\Drivers
Click Let me pick from a list of device drivers on my computer
Click Apple Mobile Device USB Driver
Click Next, then Close and exit Device Manager
Was dit antwoord nuttig?
Score 1
Voeg je antwoord toe
Kirilee zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 15
Altijd: 4,873
