Need help locating and jumping power connector
I have seen other unanswered posts to this same question: on the unmarked PCB motherboards on these newer MBPs, where are the power pins for the jump start? My power button does not work, so trying to rule out bad motherboard. Thanks!
Is dit een goede vraag?
2 opmerkingen
This may help find them: Need help locating and jumping power connector (no top case/button)
door mayer
So basically, I should try replacing the keyboard and power button first to see if it is damaged, or should i try to boot up with them unplugged? This model is new to me, and I have already tried all of the resets to no avail. As far as I can tell, the power button does not work at all. My battery works, it shows all LEDs for charge, the power adapter has a strong green LED.
door Derek
