Ga door naar hoofdinhoud
An Android smartphone by Samsung for the Asian market, known by many model numbers, released December 2014. Includes models SM-A5000, SM-A5009, SM-A500F, SM-A500F1, SM-A500FQ, SM-A500FU, SM-A500G, SM-A500H, SM-A500HQ, SM-A500K, SM-A500L, SM-A500S, SM-A500YZ, SM-A500Y, SM-A500W.
118 Vragen Bekijk alle
My volume button is going into my phone and is stuck
My volume button is stuck and is getting pushed into my phone. When I restart my phone, it is under safe mode cause my volume button is stuck. I can't disassemble the phone cause it comes in one piece of metal.
How should i unstick the volume button?
Is dit een goede vraag?
Score 10
11 opmerkingen
All phones appear to be one piece, but haven't seen any that can't be disassembled. I left my advice down below (SputnikBites) for how I handled the same with my power button. You just have to be patient & try different things. May take hours of fiddling until you notice progress because there's likely built up gunk to get it back out of. Just be careful with any of the steps. Once the volume button is out, the safe mode issue will be a simple fix. I would not start disassembling the phone unless you have some practice and understanding of such. You can easily ruin it. Check the Google/Facebook/Yelp reviews for businesses that will do it. Nowadays it's so much cheaper for simple repairs. It used to cost so much that it cost the same to replace the phone. A lot of things are only $50-$100 now. My friend went to Verizon because his camera lens cracked. They said he had to replace the one-year-old phone ($1000). I said BS and looked on Google. An hour & $50 and it was all good as new, and that included parts!
door
What did you end up doing? My wife is having the same problem.
door
i have same problem with new galaxy s10 plus…its stuck and its stuck in safe mode
door
My S8+ is doing this, were you able to fix yours?
door
i have same problem with galaxy a20s
door
6 commentaren meer tonen
Voeg een opmerking toe
11 Antwoorden
Het nuttigste antwoord
your best bet is to grab some small metal flat too to try and slide it into the housing where the buttons are. You will then try to pull the buttons back out or see if there is any metal that may be obstructing the button from coming back out. With that model, you should be able to heat the phone using a similar method to the galaxy s5 and separate the display from the frame. This would allow you to get a close up look at the issue. But if you are not well versed in phone repair, this can be a dangerous method of resolution.
Was dit antwoord nuttig?
Score 1
1 Opmerking:
Sooo I'm on the school bus and my volume button is stuck on my Samsung s6. Any tips?
door
Hi i just fixed my s7 by removing vokume key with a nail clipper now is running normal
Score 1
1 Opmerking:
Tweezers work as well
door
So my s10 slid out my pocket today at work and fell on the volume button (out of all places) and smashed the metal. Volume was stuck all the way down and stuck in safe mode. But what I did to fix it which idk if it's all galaxy's or just the s10 but the volume was not connected by any wires, so wiggle the wire side of the volume button (carefully) and it will eventually come out, take it out look at the damage, don't try to fix anything just place the volume button equally in and press equally in and it will go in and work perfectly fine, if your a lil nonphone savvy like my self then you'll prob notice the button that was stuck is a little harder to press in but still does its function. Then you can disable your safe mode and It will be off for good but also get the phone looked at after so it doesn't happen again.
Score 1
1 Opmerking:
I had dropped my S10e and my volume down key was stuck. I took some clippers and pulled the volume key out and then put it back in but then it was still turning on in safe mode. I took the volume key out again and then turned the phone back on before I put it back in. Came back on not in safe mode and my volume keys work just fine just have to push a little harder when I want to turn it down.
door
Start off by following the steps to replace you volume buttons then as you reassemble the volume you will put it back in its right place. There are currently no repair guides on this website (ifixit.com) you should check on YouTube.
Good luck
I have the same problem
1 Opmerking:
My power button was stuck so far in nothing could grab it. Didn't think I had a chance & would have to go get it repaired. I tried everything. First the alcohol and Q-Tip, listed all over the Internet. Then, the tinyist 3 in 1 oil. All the while poking and wedging with a very thin needle. I tried the nail clipper like someone else did. Just chipped off some of the button. Oops! Tried pushing the tiniest bit back and forth. I blew into it as hard as I could with my mouth around it. Covered it with my mouth, spit and pushed the spit in. Nothing budged it. After hours, I still held out hope. Tried a stiff brush w/ alcohol. Took 30 lb gorilla mounting tape pushed it onto the button & yanked at it. Tried gorilla extra sticky tape, too . I don't know which did it, or what combination, but finally I covered the button with the extra sticky tape to grab it the best I could with tweezers, yanked and it finally moved, and clicked! Yay! Continued cleaning, stuffing & wedging the needle in until it clicked easily.
door
My power button was stuck so far in nothing could grab it. Didn't think I had a chance & would have to go get it repaired. I tried everything. First the alcohol and Q-Tip, listed all over the Internet. Then, the tinyist 3 in 1 oil. All the while poking and wedging with a very thin needle. I tried the nail clipper like someone else did. Just chipped off some of the button. Oops! Tried pushing the tiniest bit back and forth. I blew into it as hard as I could with my mouth around it. Covered it with my mouth, spit and pushed the spit in. Nothing budged it. After hours, I still held out hope. Tried a stiff brush w/ alcohol. Took 30 lb gorilla mounting tape pushed it onto the button & yanked at it. Tried gorilla extra sticky tape, too . I don't know which did it, or what combination, but finally I covered the button with the Gorilla extra sticky tape to grab it the best I could with tweezers, yanked and it finally moved, and clicked! Yay! Continued cleaning, stuffing & wedging the needle in until it clicked easily.
1 Opmerking:
Yes I've just poked with a thin needle round the volume key and q tipped round with achohol and flicked up down a few times now out of safe mode and working again for now very happy x
door
I just watched a video where a guy suggested getting a cotton tip with alcohol on it (I used nail polish remover as I had no alcohol). Make sure it's not excessively wet, like dropping, rub it against the buttons and it should losen up the keys . It's worked for me on my S10+
Just suck on the volume buttons it worked for me :)))
Yes is the please help me I can remove safe mode
i did by clicking the volume down button 100 timesssssssss, increasing my volume and then trying to decrease. once it got fixed i switched off and switched on and then my safe mode was also gone. hope it helps you
1 Opmerking:
I am using S9+ but the volume just stopped working and i tried increasing its not working .
What should I do?
door
My android phone started doing this recently (S10+) and I can't fix it. Tried gentle cleaning with a q-tip, thin metal etc.
Work around.
Locate and install the Assistive Volume Button app by mCreations.
Grant permissions.
Place it next to your broken volume button on screen by drag and drop (you can also adjust the opacity, size and colour on the free version).
Then under button settings enable System Volume Bar.
Now touching the app buttons opens all 4 sliders on your system volume controls just like tapping the 4 dots on volume up/down would.
Voeg je antwoord toe
Chloe zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 13
Afgelopen 7 dagen: 113
Afgelopen 30 dagen: 423
Altijd: 70,206
