Ga door naar hoofdinhoud
The LG G4 was released in the US in early June 2015, as always focusing on high-end specifications and a refined fashion sense that makes it stand out in the premium smartphone market. Each version of the phone will have a different model number based on if it is sold by a carrier or unlocked (US or International). Some LG G4's are known to have bootloop problems.
20 Vragen Bekijk alle
It's possible to enable another 3G band
Hi , I have a LG G4 H811 from t-mobile, there is any chance to activate the 3g 900mhz band?
Is dit een goede vraag?
1 Opmerking
Activate the 3G? Why is it off? Are you still using your cell service?
door
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
Usually impossible because the hardware is actually missing some RF parts, but I have yet to check this exact model.
Was dit antwoord nuttig?
Score 3
5 opmerkingen:
I used this post: https://forum.xda-developers.com/oneplus... and enabled the band, when I restarted the phone and searched for networks I could see the WCDMA network but I could not register on it.
door
That guide only changes the parameter of the baseband ports, if the transceiver and PAs are not capable of 900MHz UMTS, it cannot work.
door
but can you confirm me if the transceiver and PAs are capable or how can I know that info?
door
That you need to check the exact circuit part list, I only know about the iPhones, which has all 2G TX on a signal route, if the 3G TX did not cover this band, you cannot connect to that band.
Maybe same for H811, it has 900 under 2G but not 3G, maybe that's why.
door
Ok, thanks for your answer.
door
Voeg je antwoord toe
Orlando zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 116
