My asus won't boot completely up after I tried to reset it to default.
My asus is a k55a and it continually reboots when it suppose to kick it a windows 10 troubleshoot after a while and if I can get there i can finish resetting my laptop. I have windows installed on a flash drive for backup, didn't know if that mattered. all I can pull up is the Aptio Setup Utility but there is no csm option or Secure boot control. So it not letting me change the boot option, also don't know if that matters but the more details the better. anyway I was trying to boot it from that usb.
Is dit een goede vraag?
Een opmerking toevoegen
Gratis verzending van alle bestellingen van meer dan US$ 100,00 of met een Pro Tech Toolkit!
Doorblader onze winkel
Ooit iets gerepareerd? Je bent een genie.
Deel je reparatie met #ImAGenius
We zijn allemaal genieën
1 Antwoord
If this problem started after an update (or system reinstall), please make sure the laptop is not connected to the internet in any way before you use the following instructions.
Try the following...
1. Power off the laptop.
2. Power on the laptop.
3. As soon as you see the rotating loading circle, press and hold the Power Button until the computer shuts off.
4. Repeat this process a few times until you see the "Preparing Automatic Repair" screen.
5. Now you want to let the laptop boot to the "Automatic Repair" screen.
6. Click "Advanced Options" and then select "Troubleshoot".
7. Here you want to select "Refresh your PC", if you do not wish to erase data, or "Reset your PC" to erase all data and restore your system.
8. From here just follow the screen instructions until the recovery is completed.
NOTE: You will need to get into the "Advanced Options" in order to get the "Refresh Option". This choice will keep your data, but any programs installed will be lost.
Do not do a "Reset" as that will wipe all data you have on the laptop.
Otherwise, MiniTool Partition Wizard can help you some way and the team had provided 8 solutions to solve this problem.
Was dit antwoord nuttig?
Voeg je antwoord toe
Blake Stine zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 Uren: 0
Afgelopen 7 Dagen: 0
Afgelopen 30 Dagen: 2
Altijd: 85
