Ga door naar hoofdinhoud
Repareer je spullen
Recht op reparatie
Onderdelen & Gereedschap
Vertical lines over LED tv
I moved my 50" 4k SEIKI to her house and it now has vertical lines on display. I did bend a video input connection as I took off coax antenna cable. Looked at that connection on board and it does not seem to be shorting anything.
Should I try to replace that board? Could cable connections have come loose?
There are several versions of this tv. I see all boards listed for sale from one with broken screen, but the one I damaged looks different. Could I just replace all with new (keep same screen)?
Is dit een goede vraag?
Voeg een opmerking toe
Essentiële Electronica Toolkit
Kleine toolkit. Grote dromen.
Shop Toolkits
Essentiële
Electronica
Toolkit
Shop Toolkits
1 Antwoord
I'm not an expert on televisions, but this looks like potential LCD damage. I see very similar lines when there is damage to an LCD in a phone or a tablet.
Was dit antwoord nuttig?
Commentaar:
there is no damage visible to screen
door
The damage could come from very tiny cracks in the LCD. They may not even be visible under the glass
door
Voeg je antwoord toe
Rich Hrad zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 22
Altijd: 827
