Ga door naar hoofdinhoud
Repareer je spullen
Recht op reparatie
Winkel
2.3L 4cyl or 3.0L V6, 6th Generation
407 Vragen Bekijk alle
What is the glue in fixing gasket on cylinder head?
What is the glue or adhesive in fixing gasket on cylinder head?
Beantwoord! View the answer Dit probleem heb ik ook
Is dit een goede vraag?
Voeg een opmerking toe
2 Antwoorden
Gekozen oplossing
Hello,
Not all vehicles require a sealant when replacing a head gasket. You will want to look in the owners manual for whether or not your vehicle requires a sealant or not. It will give you the specs need to get the job done correctly. When you are cleaning the head make sure you do not use anything corrosive to metal or any tool that could scratch the gasket area. In case you do not have an owners manual I have placed a link below where you can get it for free in a PDF file.
https://justgivemethedamnmanual.com/hond...
Please let me know this helped you!
Was dit antwoord nuttig?
Score 1
most head gaskets go on dry as they allow the head to 'slide' during thermal expansion and contraction. Thats why cylinder heads today require a very smooth surface, measured in RA's.
Voeg je antwoord toe
ferd_2773 zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 9
Altijd: 468
