The my kcup is stuck cannot remove
stuck kcup how to remove
Is dit een goede vraag?
Remove the larger insert that the k cup is installed into. I lifted it out gently with needle nose pliers it doesn't
Require any force. Then you will see a small pin sitting upward which pierces the regular pods. Swing this small gate outward and remove thereuseable cup. This rotates the itching mechanism forward releasing the cup.
Was dit antwoord nuttig?
Which part is the larger insert that the k cup goes into haha. I’m trying everything and I can’t seem to get it open!!
If it is just a regular k-cup you should be able to remove the aluminum covering the top and grab it with a pair of pliers.
This part comes out.
The pictures show the part Peter was talking about.
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 36
Altijd: 5,497
