Ga door naar hoofdinhoud
Model A1419 / EMC 3070 / Mid 2017 / 3.4, 3.5 or 3.8 GHz Core i5 or 4.2 GHz Core i7 Kaby Lake Processor (ID iMac18,3) / Retina 5K display. Refer to the older iMac Intel 27" Retina 5K Display (Late 2014 & 2015) guides as the system is very similar.
293 Vragen Bekijk alle
Which RAM do I need to buy for this iMac?
Hello everyone,
I think I want to buy the new iMac 5K 2017 i7 4.2 GHz with 8GB of RAM.
I would not buy RAM directly from Apple because it is too expensive.
I would like to update myself. But, I confess that I'm having trouble finding the right RAM for this iMac.
I would like 32GB (4x8GB) in order to have the same brand of RAM on the 4 slots.
What RAMs are available on the market?
Thank you for your answers guys!
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
Here's one source for the RAM: Ram Kits for new iMac 27" 2017 with Retina 5K display
Was dit antwoord nuttig?
Score 1
3 opmerkingen:
Thank for your quick replay Dan.
But I'm from Switzerland and order the RAM from OWC will be expensive with the shipping and the customs.
I would like to know if there is another RAM manufacturer (Crucial, Corsair, Kingston etc...) that will have the good RAM for this iMac. Like that I can order directly from a swiss shop.
I found this one from:
https://9to5mac.com/2017/06/21/how-to-up...
RAM:
http://amzn.to/2snp9u3
But the specs or not exactly the same as the iMac. Do you think these will still work?
Or do you have other links with compatible RAM?
Thanks a lot!
door
Memory specs can be a bit confusing and then the companies (or the people posting the ads on the web) don't always use the correct or complete verbiage which does make it harder still ;-{
In looking at your link for Corsair RAM on Amazon it appears to be the correct RAM. Here's a link to what Kingston is offering: Kingston Technology HyperX Impact 32GB Kit (2x16GB) 2400MHz DDR4 CL14 260-Pin SODIMM Laptop HX424S14IBK2/32
door
@carlitostyle - which RAM did you finally buy and where (which shop?) did you get it from? Interested because I live in Switzerland as well.
door
Voeg je antwoord toe
carlitostyle zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 1
Altijd: 3,153
