Ga door naar hoofdinhoud
JBL Flip 4 portable speaker. IPX7 waterproof bluetooth dual driver speaker that won the CES Innovation Award 2017.
Why playing via AUX cut's on quiet passages in the songs/movies?
There is this problem with JBL Flip 4, I think that playing via AUX sound is more controlled, clearer bass and less distortion. But it cuts out the sound on quiet passages in the songs, or in the movie, it soo annoying. Does anyone have a solution? It works fine with BlueTooth, but let's say, movies, the sound has a delay via BlueTooth so it's weird.
Is dit een goede vraag?
Score 22
5 opmerkingen
i have the same problem.still have no the solution
door
I have same problem with my speaer. I would never expect such bug from JBL and I will return speaker back. JBL is doing nothing to fix this bug
door
Still a problem for me. Tho on JBL Charge 3. Its annoying cause I updated the speaker thinking I would get rid of a problem I used to have where the speaker would "sleep" after not playing anything for a few minutes and it would then take like 30 seconds for it to wake up.
door
I have encountered a problem and am working on it and need various advice on the forum.
door
This is a typical situation these days: manufacturers don't give a f#&§ about their products beucause of insanely fast moving production cycles and cutting costs for support, service and quality management.
I wanted to get rid of the stupid startup sound on my JBL Charge 3, which was only possible after a firmware update to version 7.6, using the JBL Connection app. After the update, I get sound dropouts using AUX, also there are now frequent issues connecting via Bluetooth.
Very disappointed in JBL, I rather will buy a Chinese Anker speaker instead of another JBL Charge... **slow clap**
door
Voeg een opmerking toe
9 Antwoorden
Het nuttigste antwoord
Hi, dude!
I had the same problem with my JBL flip 4, but i know how to solve it. Try to set max volume on your device and then set optimal volume with +/- buttons on speaker. If the sound from connected device is low, flip 4 is cut it out. I don't know why, but it is so.
I hope that I helped you.
Was dit antwoord nuttig?
Score 15
5 opmerkingen:
This is the simplest and most effective solution. Thanks a ton!
door
Thanks, mate, I was going nuts until I saw this fix!
door
Thanks, that worked. Was really irritating.
door
I came here to write the same solution. Thank you! There is no way any engineers would create faulty product on purpose. They just tested it with knowledge about sound, not bout users. Cheers :)
door
Very thnx pro 👍 great
door
As a workaround, you can run a signal generator app in the background, set to very low frequency like 20 Hz, and low but not too low amplitude. Flip4 will reject this frequency and not distort/waste power, but it will be alive all the time.
Score 9
5 opmerkingen:
Thanks a lot, i find even 1hz is enough to solve the problem. Bit annoying to set up every reboot but at least it solves it.
door
Can you suggest a signal generator app?
door
Thanks for this. I am using Audio Measurement System to generate a 20 Hz signal with -30 dB, which solves the issue. You can find the app here: https://sourceforge.net/projects/audmes/.
Other options for signal generation can be found here: https://listoffreeware.com/best-free-sig...
I also emailed JBL about this issue. Let's wait and see.
door
thank you it's working.
door
It really helped. For those looking for it, at least in JBL Charge 4 you can activate the low frequency mode by holding down the minus and bluetooth buttons simultaneously for ten seconds.
door
Hi, I’ve found that going into the so-called “low frequency mode” fixes it completely - after also having made a firmware update (so my firmware is now as of 1-aug-2020).
For those unaware, “low frequency mode” does not put in a low frequency booster, as it might sound, but instead disables the sound processor. The same sound processor that cuts out quiet sounds also cuts low frequencies at high amplitudes, to avoid distortion - therefore they call this disabling “low frequency mode” because there will be no more low frequency CUTTING. So, thank you JBL, but I like my sound just as it is; if it’s so loud that it distorts, I can take care to lower the volume or put in an equalizer as I desire.
So:
longpress bluetooth + volume minus - go into “low frequency mode” a k a unaltered sound; longpress them again to return to “processed mode”
Restarting or shutting down reverts to the default “processed mode”.
Score 9
7 opmerkingen:
thx that fixes the problem (no firmware update)
door
Unfortunately doesn't work with the Flip 3, but the soldering fix above (by @deepsoic ) does works with that model.
door
Created an account just to thank you, champ! Solved the problem on my Flip 4.
door
Same as above, I created this account just to say thanks. I have had this issue for years and had no idea how to solve it till now!
door
Thank you man! Too bad that no one know such feature exists
PS I've also registered just to thank you
door
2 commentaren meer tonen
It is possible to hack the pcb to fix it. Extract the board, locate Q12, and solder a wire that shorts its collector (middle terminal) to ground. This will make Flip 4 think there is always audio going into aux.
You may also want to remove 33-ohm resistors, that may reduce distortion for signal sources that have high-ish output impedance.
This hack causes a few side effects though: Bluetooth pairing sounds will not be played. Bluetooth audio does work, just no pairing sounds.
Score 3
5 opmerkingen:
Thank you for the deep detailed info. If the transistor is shorted, would it may be a good idea to cut AUX channels off after (or before) R148 and R106 ?
For my very unexperienced view it looks like the whole block has no function then.
door
@Frank Weichert yes. And it is likely to improve the sound a bit, as the transistors are a very nonlinear load, and can cause distortion if music source output impedance is high.
door
I have a similar issue with my bluetooth speaker, not a JBL.
and the soldering hack work. thank you so much.
but, I guess, now the speaker think that there is audio signal all the time and will not sleep. It will keep turned on until the battery died.
Is it as expected?
door
Applied the same fix on the JBL Flip 3 and voila, no standby mode. The PCB layout is almost identical and I think your schematics picture is in fact from a Flip 3 service manual? The PCB is glued in place, I was able to solder the little wire through the speaker openings without removing the PCB.
https://i.imgur.com/C2xZBTR.jpg
Now I realize though that my input (from an Orange Pi single board computer) is quite noisy, I wonder if a better audio cable will help, not sure if mine is screened.
door
Hello, I tried this hack in my flip4, and it didn’t work at all….when plugged aux only, it plays around 10-15 minutes and turn off, it only stays on if the Bluetooth is paired together…already bypas the Q12 (grounded) and both r148 and r106 33ohn resistors cut out, but in aux input only it keeps crashing down….
door
I don’t have a fix fix, but I have found that I can turn on a YouTube vid of a constant 12hr dog whistle and that will keep the speaker awake.
There is still sound coming through the speaker, but you can’t hear it, so it doesn’t interfere with whatever you are listening to.
Might annoy ya dog though. But I turn YT’s volume down really low and that still keeps it awake.
You would think in the 2 year span from the original post that JBL would have figured it tf out.
Score 3
What I did to get around this was plug it into power, BUT, when I tried to fix this issue while plugged in with an iPhone charger(the dinky 5w one that comes in the boxes of most iPhones), it did NOT work. I used a more powerful wall adapter and there is no more cutting out. Hope this solves your issue:)
Score 1
hello! I have JBL Charge 4, and it have the same problem!! All that I notice after half year of using is that the speaker’s aux volume is saving separately from volume via bluetooth. How it helps me: I simply set low aux volume on the speaker and adjust volume on Device. The stronger is signal, the less cuts would be. Unfortunately, it doesn’t work ideal, but it can helps with 80% sounds you play. So, JBL, PLEASE FIX THIS STUFF!!
2 opmerkingen:
Hi,
Maybe you should contact JBL via email about the problem.
i'm pretty sure that they're not reading this forum.
The more people that tell them about the problem, then eventually they might listen
door
you are right, mate )
door
In order to prevent the cut out between the TV and speaker through AUX, you gotta lower the volume on the speaker and increase the volume on the TV just to get a stronger signal from the output. Cause during the quite part of the movie e.g talking, are low on signal compared to part where there's music. If you turn the TV volume above half way it'll fix the problem.
Happy holidays all. ,
I’ve come across a few theories that might be useful…. one theory points to the Realtek drivers to be the issue at the registry level. It basically gives you instructions to edit the registry which ALWAYS freaks me out when going in there. I would provide a link but I can’t seem to find it. However, I did manage to screenshot it.
The other theory I ran across is not a solution but more like a band-aid. No special skills or tools required and therefore a link nor screenshot was not merited. Simply access a streaming medium like Amazon Prime Music and pause it. Apparently, this causes the audio to be in stand-by mode and allows for uninterrupted playback - no “gaps / breaks”.
This next theory is a time hog and may take a little prep / planning as it is “hands-on” approach. That pretty much eliminates that option for me. Basically, you’ll be like “detailing” a car but instead it’s on your audio equipment. Thoroughly clean all the “male” and “female” ends / ports with appropriate cleaning agent, inspect all soldering points on the circuit boards, inspect all cables for any irregularities and adjust accordingly.
Using audio splitters will not affect performance, of course contingent upon it’s build quality and materials. This also applies to any cables being used. The shorter the cable, the less tendency for latency issues.
I don’t use microphones for anything but, if you are using microphones, apparently using an adapter or a special 3 pronged assembly will help minimize any issues. Bearing that in mind, that’s all my input regarding microphones.
Amidst the vast amounts of reading and hours sitting in one place, I came up with bupkis. Time for a dose or two of King Louis XIII and resume tomorrow. Hope my experience helped at least one (1) person out there. May the Schwartz be with you. =)
p.s.
https://www.soundguys.com/the-ultimate-g...
https://www.sony.com.au/electronics/supp...
https://www.audio-technica.com/en-us/sup...
1 Opmerking:
Hi I was having this issue with a JBL Charge 3 but I believe these ar all similar. I found some info regarding putting the speaker into an aux and power input only mode. When in this mode th Bluetooth is disabled as well as the battery is disabled.. so you have to be plugged into power when in this mode. It seems to stop or minimize that aux input delay when in this mode. You press and hold two buttons for ten seconds to enable and disable this mode. I believe it was the volume up and the Bluetooth or the connect button. Btw the battery will still charge and one other advantage is if you have the power plugged into the the USB on a TV for example the speaker will tu n on and off with the TV which. Is nice.
door
Voeg je antwoord toe
Peter Susič zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 5
Afgelopen 7 dagen: 27
Afgelopen 30 dagen: 141
Altijd: 34,337
