Ga door naar hoofdinhoud
Released in 2017, the Razer Tiamat 7.1 is an over-ear gaming headset with microphone and audio control unit.
6 Vragen Bekijk alle
I need a inside picture of volumecontroller , cables are disconnected
Hello Ifixers,
My tiamat 7.1 is on the shelf since month, I tried to fix it month ago, but without success ... I need the color code/or a precise picture of the inside of the volume controller to reconnect the audio Output wires.
I would give you a million thanks if you could help me :)
MrWisest
Is dit een goede vraag?
Score 1
Voeg een opmerking toe
3 Antwoorden
Gekozen oplossing
Hello, I just saw your comment. Hereis the pinout of the wires going toward the headset from the sound board
Here are the wires attached down the left side of the PCB (when looking at the bottom). From the edge of the PCB inward they are:
Solid copper, going to F_B
red/green spiral, F_L
Solid Green going to S_R
Red/copper spiral going to S_L
Solid red going to R_R
blue/green spiral. going to R_L
Above that a large black cable carries a white wire to M+ and a copper to M-
Here are the wires attached at the bottom of the PCB. From the corner of the PCB outward they are:
two blue/copper cables going to GND2
Red/Blue spiral going to Cen_L
Solid Blue going to Cen_R
Solid Black going to Sub_R
Solid Black going to Sub_L
Two Green/Copper cables going to 5V
Two Blue/copper spiral going to -
If you need the pinout for the other side of the board (towards the computer,) just ask.
Was dit antwoord nuttig?
Score 2
Hello TwixOps,
I am really greatfull for your answer. I don't actually have the time to meddle with the headset right now, but I'll definitely try again later thanks to you ! :D
I hope it will help some other than me :)
Edit : I DID IT ! It works now :D
Though there is some minor error in your coloring :)
On the first picture, the first "Solid copper, going to F_B" I thought F_B, hmm Front_Back, it didn't felt really thing, I rapidly guessed you meant "F_R"
Then on the second picture :
"two blue/copper cables going to GND2" should be "two black/copper cables going to GND2"
The rest was okay, and the pictures precises enough to understand why you had four "blue/copper cables"
Thank you again !
Wisest
hope u can write the solution for the end side (towards the computer) because my friend burned it :( .. all i want to know is the job of every color .. because i will only use the microphone and the headset and what parts should i connect to the usb side . i tried to connect it as a normal headset and the red and black cables to a usb wire as a power source, without the microphone but the sound is bad and too low xD ! thank u in advance bro <3
Voeg je antwoord toe
MrWisest zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 3
Altijd: 1,167
