Released September 25, 2015. Model A1688/A1633. Repair of this device is similar to previous generations, requiring screwdrivers and prying tools. Available as GSM or CDMA / 16, 64, or 128 GB / Silver, Gold, Space Gray, or Rose Gold options.
1756 Vragen Bekijk alle
Headphone jack, vibration, & loud speaker not working?
The loud speaker stopped working , I changed the piece out & it still does not work. A day later the vibration & headphone jack is not working ? But the charging is working. Could it be that the cable is not plugged in correctly or maybe I should replace the whole charging/headphone jack flex ? How can I fix this ?
Beantwoord! View the answer Dit probleem heb ik ook
Is dit een goede vraag?
Commentaar:
Hello, i have same problem, no sound no vibration just charging, i tried change charging port but still same problem. HELP me please. Can be this $@$* problem with audio ic?
door
Een opmerking toevoegen
Gratis verzending van alle bestellingen van meer dan US$ 100,00 of met een Pro Tech Toolkit!
Doorblader onze winkel
3 Antwoorden
Gekozen oplossing
It's, yeah..you need a new Lightning dock
iPhone 6s Lightning Connector Assembly Replacement
iPhone 6s Lightning Connector and Headphone Jack
iPhone 6s Lightning Connector and Headphone Jack afbeelding
Product
$34,99
Was dit antwoord nuttig?
Score 1
replace the charge port that should fix the issue
Commentaar:
I just replaced my flex cable w lighting port and have no sound or vibration but phone now charges
door
Need to ensure if the speaker pins sits without disturbance on the copper pad of the charging /lightning connector assembly itself. This correction also solved issue of vibrator which was not working.
Voeg je antwoord toe
samantha_luvs_you0 zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 Uren: 5
Afgelopen 7 Dagen: 23
Afgelopen 30 Dagen: 116
Altijd: 2,449
