Ga door naar hoofdinhoud
Repair and disassembly guides for guitar amplifiers.
69 Vragen Bekijk alle
My guitar amp fm212 when I plug input jack makes popcorn noise.
My guitar amp fm212 when i plug input jack makes popcorn noise, when i plug the guitar cable make hudge noise like pumping ur popcorns pumping.... when i take the jack of finish, i tested several jack cables and diferent channel amp even the pre in and makes same noise,...
Is dit een goede vraag?
1 Opmerking:
true when theres nothing plug in theres no noise, only when i plug any cable even working one i`ve tested in other amp, does that sound like popcorns…. will try to replace the input jack piece.
door
Voeg een opmerking toe
1 Antwoord
Sounds like you either have a jack that has broken the solder connections to the circuit board or a piece of a plug came off and is stuck inside the jack or else you have a jack that the plug is just too loose due to age and slight bending of the parts that make contact inside the jack. Of course it might just be a bit of corrosion in the jack. I am assuming of course that the “popcorn” sound goes away when there is nothing plugged into that jack.
Was dit antwoord nuttig?
1 Opmerking:
This does sound like bad jacks, no noise with nothing plugged in, same noise with different cables plugged in. I would replace the jacks with high quality parts.
door
Voeg je antwoord toe
filipeyakuza zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 4
Altijd: 193
