Why won't the arm that raises and lowers the deck raise or lower?
No spring action in arm. Was cutting grass, stopped, went to raise arm and nothing. Stuck down and won't cut grass.
Is dit een goede vraag?
This could be a result of a connection somewhere that broke loose like the lift links not being connected. If you could give me a model number of the mower I could maybe find a diagram to help you find those lift link and connections.
Was dit antwoord nuttig?
Hey Justin, i'm having the exact same issue with my Murray. Is it possible that you can find me a diagram of the lift links or springs that connect to the arm to raise and lower the deck? Model Number 42516X92B/skynz71@yahoo.com
Having the same problem with my cub cadet 1420. Could you possibly find a diagram for it? Thanks
I have a husqvarna GTH2654 the deck won't raise or lower either.
The front end of the deck that connects to the rod wont raise on my troy-bilt hydro
Lifting arm will not raise mower deck on XT1 w/ 46” deck?
Afgelopen 24 uren: 6
Afgelopen 7 dagen: 30
Afgelopen 30 dagen: 95
Altijd: 6,377
