Ga door naar hoofdinhoud
2.2 GHz (Turbo Boost up to 3.4 GHz), 2.5 GHz (Turbo Boost up to 3.7 GHz), or 2.8 GHz (Turbo Boost up to 4.0 GHz) quad-core Intel Core i7 processor with 6 MB shared L3 cache.
768 Vragen Bekijk alle
Can I test my MBP with 1 fan only?
Hey guys.
I have a brand-new 2 months old rMBP 2015 and it is making an annoying noise. Mostly right after wake up or when I start Chrome.
I figured it is either the CPU or one of the fans. I a very dry pop sound, like a knock.
Would I be able to disconnect one fan and test the machine for a few days like that? Or Id fry it all up?
Is dit een goede vraag?
Score 1
Voeg een opmerking toe
3 Antwoorden
Gekozen oplossing
So guys just out of curiosity and in case anyone else ends up with the same weird pop noise coming from the top case, I discovered what was happening. And it wasn't the fan.
I tried disconnecting both fans and the noise wouldn't cease. Then I tried turning the machine on with the bottom open and I realized that the noise came from the heatsink.
It all makes sense now. When the chip gets hot due to Chrome or Photoshop, fans kick in and that's why I thought they were the culprit. However after ruling them out, I tried pressing down a bit on the heatsink only to find out a couple of screws were loose. Both the type that connect the heatsink to the case and the ones that push the springs down the chip. After tightening those out everything seems to be fine. At least for now.
It makes sense the chip would go from cool to hot very fast, thus making the fragile screws+spring vibrate and pop. If the noise comes back though, I have no idea how I'll solve it haha
Was dit antwoord nuttig?
Score 1
Het nuttigste antwoord
This is covered under warranty since it is only two months old. Have Apple replace it for free.
UPDATE 5/30/17
Just take the bottom off, unplug one fan and see if it quits making noise. Then try the other one. repairs don't get much easier. Just click on the icon to get to the guides.
Here's the right fan: MacBook Pro 15" Retina-scherm mid 2015 Vervanging van de rechter ventilator
and the left:
MacBook Pro 15" Retina-scherm mid 2015 Vervanging van de linker ventilator
The guide has a link to the part and lists the tools you'll need.
MacBook Pro 15" Retina Display Mid 2015 Linker ventilator Afbeelding
Handleiding
Moeilijkheid:
Gemiddeld
15 - 40 minutes
MacBook Pro 15" Retina Display Mid 2015 Rechter ventilator Afbeelding
Handleiding
Moeilijkheid:
Gemiddeld
40 minutes - 1 hour
Score 4
1 Opmerking:
I'm not sure how long it would take for them to realize what the problem is. I'm guessing they wouldn't replace the fan without extensive testing? I just can't be without a machine for 4 days. Also I'm terribly worried they might scratch the macbook too :(
door
Not for a few days. I would suggest removing one and seeing if its the issue. For light loads for maybe 10 minutes to an hour it should be ok but for days, that might do some damage.
The guides are below.
Left fan
Right Fan
Handleiding
Moeilijkheid:
Gemiddeld
15 - 40 minutes
Handleiding
Moeilijkheid:
Gemiddeld
40 minutes - 1 hour
Score 2
8 opmerkingen:
Got it.
What are the odds of a noise coming from the CPU though?
door
Very low odds. When you say it is new, what do you mean? Where did you get it? Was it previously used?
door
No, bought it from apple 2 months ago.
door
CPU cant make noise. Its just a chip
door
Sorry, I meant some sort of noise related to increasing heat or maybe current (?) that is generated when the CPU's frequency rises. Would something like that be possible?
door
3 commentaren meer tonen
Voeg je antwoord toe
allanwl zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 2
Altijd: 496
