Released on September 19, 2014, this 4.7" screen iPhone is the smaller version of the iPhone 6 Plus. Identifiable by the model numbers A1549, A1586, and A1589.
4560 Vragen Bekijk alle
iPhone 6 error 56
I have an iphone 6 that was updated thru settings to latest iOS and failed and needed to be restore with iTunes. I did so like 5 times now and it keeps failing with error 56. I've tried new cables, new dock connector, latest iTunes, tied both windows and Mac OS but it keeps giving the error. what causes this and how can I fix it? Thanks
Beantwoord! View the answer Dit probleem heb ik ook
Is dit een goede vraag?
Score 1
Commentaar:
Hi I have the same problem on iPhone se and i fixit. What i was try to do was remove the battery connector to drain the power from the phone but as i use screwdriver to remove the conector there was sparcle so I thing the phone reset as when i try to turn the phone on it show low battery logo and after i restore the phone and it work.
door
Een opmerking toevoegen
Gratis verzending van alle bestellingen van meer dan US$ 100,00 of met een Pro Tech Toolkit!
Doorblader onze winkel
4 Antwoorden
Gekozen oplossing
Asked and answered:
What is (unknown error 56) iPhone 6
Was dit antwoord nuttig?
Score 4
100% solution
NFC IC REBALL & JOB DONE
100% TESTED
Score 1
Commentaar:
hello brother
i have done for your idea
very thanks
but my iphone 6 done for error 56 but wifi not work it's Gaye
door
Yeah from days of research and a @%^$$@$ iPhone that is still stuck, I have concluded that it is either the NFC chip (which was working perfectly fine, I have no idea why it died), or my touch id button (tried original and spare ones, original is cracked and touch id may no longer work, but chip on it is in working condition, or my cables/$@$*!& wiring. Someone please help me before I hang myself. Why are androids so easy to fix and iPhones stubborn @%^$$@$# who can't take the slightest beating from command prompt or terminal? Its always the iTunes $@$* that gets me every time. Anyways I am buying a new iPhone tomorrow with hopes that I can have a working phone, but chraiglsist seller isn't responding and I am getting nervous and sad. &&^&^$^ !&&* I am killing myself.
Score 1
Commentaar:
I relate in many ways
door
sometimes error 56 is caused by the power supply of camera on iphone 6.
exchange the both camera(which i dont think it would works) and check the cricket might fix ur problem.
Voeg je antwoord toe
CAB zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 Uren: 1
Afgelopen 7 Dagen: 2
Afgelopen 30 Dagen: 9
Altijd: 3,534
